Speed car
fernandosc3d
Speed car
Post by fernandosc3d » Wed Mar 10, 2010 2:13 pm
Using Autonomous Mode making the car the way the line I can do with the car to speeds alternate?
Re: Speed car
Post by Patrik Martin » Wed Mar 10, 2010 4:07 pm
fernandosc3d wrote:Using Autonomous Mode making the car the way the line I can do with the car to speeds alternate?
Are you asking how to make the 4-Wheeler Extended to follow the spline exactly?
fernandosc3d
Re: Speed car
Post by fernandosc3d » Wed Mar 10, 2010 6:07 pm
No, I know how to the target (green cross) go faster, if the line is small target is too slow if it is large target goes faster! I want a small line in the target walk fast
Re: Speed car
Post by Patrik Martin » Wed Mar 10, 2010 6:35 pm
fernandosc3d wrote:No, I know how to the target (green cross) go faster, if the line is small target is too slow if it is large target goes faster! I want a small line in the target walk fast
The way 3ds max (i guess this is what you are using) with path constraint works is that it makes keys on the spline in the begging and one in the end of the timeline. If you like for the TargetMesh to go faster on the spline you need to first select the TargetMesh so that you are able to see the keys in the timeline in the bottom and then pull the last key towards the begging of the timeline.
Users browsing this forum: No registered users and 14 guests
