Camber angles with Craft 4-Wheeler Extended
Post by Carl Buhre » Fri Aug 15, 2008 3:14 pm
You can create this, but it has to be done after the recording has been done. Once you've record the animation for your vehicle, select WheelerExt_WheelRelocatorMesh_FRTransform (for example), rotate it to the desired angle and set a key frame (setting a key frame is only needed in Maya, 3ds MAX has auto key frame on by default).
Re: Camber angles with Craft 4-Wheeler Extended
Post by Luigi Tramontana » Fri Dec 12, 2008 2:15 pm
The upcoming hotfix update will enable this even during record (this and much more!)
Users browsing this forum: No registered users and 0 guests
