How to change the Max speed of the car?
roxyliao
Post by roxyliao » Fri Jan 13, 2012 10:31 pm
Hi I am testing the 4 Wheeler Ext with Autonomous Mode in Maya (2012x64).
Since our car is in real world scale the WheelerExt_CarBodyMeshTransform is scaled to about 500. (we keep Maya's default unit: cm) It seemes to mess up the max speed and the car can't drive fast enough to follow the TargetMesh. Are there settings in the 4 Wheeler system that is unit-sensitive? What configuration should I change so the World Space Maximum Velocity Gauge makes sense?
Daniel3d
Re: How to change the Max speed of the car?
Post by Daniel3d » Fri Jan 20, 2012 5:40 pm
Hi, I am having the same problem with the 4-wheeler ext, no parameters that I change alter the speed of the car rig following the target mesh. my evaluation period has expired, so I used the create tab that provides 'limited functionality' is this a causing the speed to be restricted? my scene scale is in meters and the scale of the rig has not changed from the default.
thanks for any help
Dan.
Daniel3d
Post by Daniel3d » Fri Jan 20, 2012 6:09 pm
Hi again, I changed the profile for 4-wheeler ext to 'autonomous mode - standard' (originally I had it on sports car) and this seemed to help a few settings needed tweaking but the speed of the car increased.
hopefully this should help
Dan
Post by Patrik Martin » Mon Jan 23, 2012 8:53 am
Actually it does not mess up the max speed. What you need to do is to change the Gas Pedal (Forw/Backw) value in the Input properties group in the configuration for the 4-Wheeler Ext to a higher value.
Daniel3d
Post by Daniel3d » Mon Jan 23, 2012 10:46 am
Hi thanks patrick that worked.
Users browsing this forum: No registered users and 334 guests
