Hi guys I download the latest version 10.1.4 for OSX 10.6.7
I cant for the sake of me use the space bar to move around in Maya it always tells me
// Error: Cannot find procedure "CraftStopAnimationCmd".
even though the plug in isn't even loaded .... whenever I load the plug in it doesn't give me anymore the error but I can't still use the space bar in Maya.
Any clues please ....
Thank You.
Maya 2011 Error with 10.1.4
Re: Maya 2011 Error with 10.1.4
Hi Sepu,
The key shortcuts in Maya have been altered. I have heard other having this problem before and i think CDS may override the default behaviour of space to be used to stop the recording.
The maya Key shortcut dialog is everything but intuitive. If you don't use any special custom key bindings i would recommend you simply reset the configuration to factory settings and your problem should be solved.
that worked Thank you.
Do u know if this just happens sometimes or every time that I tried to use CDS will this happens?
Anyhow .. thanks again.
Users browsing this forum: No registered users and 20 guests
