Autonomus Skidding
jigi525
Autonomus Skidding
Post by jigi525 » Fri Jan 28, 2011 10:44 am
Hi there !!
I have got a problem using craft director studio 10.1.2 in maya 2011.
The scene i want has a car skidding on a curve but not going off-road. So i decided to use speed spline controller to set the path along the curve and set the mode to "autonomous- slippery'. Also tweaked a few settings here and there but the car goes off-road. I increased the "Gas Pedal Maximum" so that the car follows the carriage tightly and skids simultaneously. But it doesn't.
So what i want:
A setting where the car follows the carriage tightly and skids when taking a turn.
Do we need to change the particular waypoint's settings or the profile itself or the 4-wheeler extended's properties???
Waiting for help !!
Re: Autonomus Skidding
Post by Patrik Martin » Mon Feb 14, 2011 11:51 am
I would change to spline to fit the cars way of moving and tweek the different configurations to get it as I like. You can also use the gamepad at the same time as you use autonomous mode if you like to controll the skidding manually.
Users browsing this forum: Majestic-12 [Bot] and 177 guests
