I can't link the crawler tracks on a non-flat ground, a land of my work.
I do not understand!
Your Help Is Greatly Appreciated.
cheers
Proposer une
crawler tracks
Re: crawler tracks
Hi Samy,
I assume it's the gravitydirection mesh you try link to the ground, not the crawler mesh itself?
Are you running 3ds max? Try convert the ground to an editable mesh. 3ds max usually has no problem with this, but it might be the case. If you don't want to convert your ground to an editable mesh, clone it and convert the copy, then use the copy to drive on while hidden.
Hope this helps. Otherwise, please give me more information about the scene and i'll see what i can do. If you wish me to take a look at the scene, please email us as support@craftanimations.com and i will set up a way for you to upload the scene.
Re: crawler tracks
Do you have a ftp so I can send you my scene?
Users browsing this forum: No registered users and 20 guests
