I have a problem with the 4Wheeler Ext and the autonomous mode (I'm working with Cinema 4D 11.5). The wheels seem only spinning correctly when I keyframe the targetmesh veeery slowly. As soon as I'm moving the target a little bit quicker, the wheels start to spin way to fast and after a few seconds they seem to stop spinning and only moving along the spline. Maybe it's a skaling issue ? Can I configure the wheels to spin much slower ?
cheers
wheel spinning problem
Re: wheel spinning problem
Hi Wombat,
Could it be aliasing effects? How fast are the wheels spinning? Try increasing the animation framerate during recording to see if it helps.
Hi Micael,
when I select the pan or rotate gismo of the wheel I can see the gismo spinning during the animation and the render is also ok - so the illusion of the non-spinning wheel is only concerning the wheel polygons inside the viewport. That's no problem for me.
Thanks and best regards
Users browsing this forum: No registered users and 79 guests
