4 wheels problem Cinema 4D
freak78
Post by freak78 » Fri Nov 13, 2009 2:06 pm
Hello Craft Team,
I have Cinema 4D and 4Wheeler Free. The Wheels go to the half in the Ground ? The Problem is the Scaletool from Cinema 4D.
Image Image
Scaled in the "Koordinate" on right Side is this ok ! Scaled with the Scaletool is the Problem avaiable.
Please Help.
Re: 4 wheels problem Cinema 4D
Post by Carl Buhre » Fri Nov 13, 2009 2:14 pm
GravityDirectionMesh needs to be a child of your ground object and the ground object must be Editable (Hotkey: C).
freak78
Post by freak78 » Fri Nov 13, 2009 3:33 pm
Carl Buhre wrote:GravityDirectionMesh needs to be a child of your ground object and the ground object must be Editable (Hotkey: C).
The Problem is the Scaletool from Cinema 4D. When i Scale the CraftCar-Mesh with the Scaletool go the wheels to half in the Ground (GravityDirectionMesh->ConvertetGround).
When i Scale per Hand in the right Side under the Objektlist-->Koordinate is no Problem.
Post by Carl Buhre » Fri Nov 13, 2009 3:42 pm
You have to use the Object Tool when you scale, otherwise you're just scaling the dummy mesh data, not the transform. See the attached picture to this post.
freak78
Post by freak78 » Fri Nov 13, 2009 3:56 pm
Thanks !
This is it !!!
gcpdesign
Post by gcpdesign » Sun Nov 15, 2009 5:21 pm
Similar problem
All is made by rules, but the car fails in the ground. Why?
Post by Carl Buhre » Mon Nov 16, 2009 3:29 pm
gcpdesign wrote:Similar problem
http://forum.craftanimations.com/viewto ... ?f=2&t=626
Users browsing this forum: No registered users and 477 guests
