Can anybody guide or help me how to modify the tamk with a flaccidity track too much I should very appreciate for your helping me!
In Recording, I noted my tank's tracksteps are flaccidity too much. I tried to increase its parameter value: Flaccidity Reduction = 8 and so on, but nothing worked! Where's the mistake?
How to modify the tamk with a flaccidity track too much?
- Henrik Hansson
- Senior Plug-ins Developer
Re: How to modify the tamk with a flaccidity track too much?
Hello sniperswf!
One way to remove flaccidity even more is to increase the number of subframes. This will increase the accuracy of the simulation. This is the parameter just below the Flaccidity Reduction parameter. The default value is 10, so try with a value like 15-20. Be careful increasing it to much, cause it can slow down the simulation time alot.
You can also try to increase the Bending Stiffness and Bending Damping to get a more stiff track.
Hope this helps!
/Henrik
Hope this helps!
/Henrik
Another method to counter a bouncy track is to create a row of support wheels to block it from getting outside of regions where it's not supposed to.
Dear Henrik,Henrik Hansson wrote:Hello sniperswf!
Hope this helps!
/Henrik
Thank you very much! I'm ok now.
Dear Carl Buhre,Carl Buhre wrote:Another method to counter a bouncy track is to create a row of support wheels to block it from getting outside of regions where it's not supposed to.
Users browsing this forum: No registered users and 142 guests
