Variable-sweep wing aircraft question
Enigma229
Post by Enigma229 » Wed Apr 22, 2009 4:14 am
Hey guys,
I'm thinking about going into the skies with my next animation and have an AirplaneExt question. Basically, I have an aircraft and when I go into afterburn, I want it's wings to move back (like a variable-sweep wing aircraft does). Can I achieve this by using a combination of the AirplaneExt and say, DirectInputLink or would you have another idea?
Re: Variable-sweep wing aircraft question
Post by Carl Buhre » Wed Apr 22, 2009 10:58 am
Enigma229 wrote:Hey guys,
That will probably work or you could use a combination of the AirplaneExt and MultiStateMachine.
Enigma229
Post by Enigma229 » Wed Apr 22, 2009 2:33 pm
Ok, but how to set-up so that an input from the AirplaneExt will control a MultiState and/or DirectInput? I don't see any options for this.
Post by Carl Buhre » Wed Apr 22, 2009 2:36 pm
I guess you can use the same button for both inputs but the virtual inputs are not available for the after burner, yet. I will inform Luigi, I'm sure he can implement it to the beta version of Airplane Extended.
Luigi Tramontana
Post by Luigi Tramontana » Wed Apr 22, 2009 11:10 pm
On the other hand the easiest way to do this is to use the same button you use for the afterburner to also control the DIL ;)
Enigma229
Post by Enigma229 » Thu Apr 23, 2009 4:02 pm
Luigi Tramontana wrote:On the other hand the easiest way to do this is to use the same button you use for the afterburner to also control the DIL ;)
Ah yes. Very simple solution. Thanks Luigi.
Users browsing this forum: Bing [Bot] and 46 guests
