Weird missile guidance behavior
Vipera
Post by Vipera » Fri Aug 11, 2023 1:09 am
I am trying to use Missile operator to simulate missile launch from ground launcher. I am having a problem with missile orientation during initial missile flight path. The problem is that even missile moves up the missile orientation is with nose down. I tried to tweak various parameters but I cannot eliminate such behavior. What do I have to change to fix it if this is really possible?
Re: Weird missile guidance behavior
Post by Patrik Martin » Fri Aug 11, 2023 11:32 pm
Yes, that looks a bit odd. The target where is it? on the ground?
Vipera
Post by Vipera » Tue Aug 15, 2023 4:39 am
The target is behind the image frame at left top corner, about few hundred meters away.
Vipera
Post by Vipera » Tue Aug 15, 2023 9:22 pm
Here is .max file with CA missile animation where I have problem with missile orientation during flight.
https://www.dropbox.com/scl/fi/8yhru70c ... 3e6oa&dl=0
Users browsing this forum: No registered users and 279 guests
