Multiple Ground Meshes
patrick58d
Post by patrick58d » Thu Feb 24, 2011 6:37 pm
In our scene we'd like to use multiple meshes as a ground plane without combining them into one mesh. Is their a way to accomplish this with parenting? We have tried different hierarchy combinations without any success. In this craft tutorial video this topic is briefly mentioned at around 27 seconds and the possibility of parenting is mentioned. http://www.youtube.com/user/craftanimat ... cHtpSIvJC8
We are running craft version 10.1.4x64 in Max 2011. Thanks in advance!
Re: Multiple Ground Meshes
Post by Patrik Martin » Fri Feb 25, 2011 12:16 pm
Parent/Linke the ground meshes to the GravityDirectionMesh. This only works for the 4-Wheeler Extended.
patrick58d
Post by patrick58d » Fri Feb 25, 2011 11:29 pm
Hi Patrik,
Thank you for your reply. This is exactly what I have done. I've parented (linked in the case of MAX) the GravityDirectionMesh to the multiple ground meshes with no success.
Post by Patrik Martin » Mon Feb 28, 2011 10:07 am
patrick58d wrote:Hi Patrik,
Try the other way around. The meshes to the GravityDirectionMesh.
patrick58d
Post by patrick58d » Thu Mar 10, 2011 8:16 pm
Hi Patrik,
Thank you for your reply. I have tried ever possible parenting combination, and none seem to work including parenting the ground meshes to the GravityDirectionMesh.
Post by Patrik Martin » Fri Mar 11, 2011 8:31 am
Strange... are you able to place a link to the scene so that I can have a look at it? Remove the things that are sensitive if you like. Also it's good if you tell me which version and program that you are using.
Users browsing this forum: No registered users and 15 guests
