hi every body...
how can you make an accurate interaction between a tire and an obstacle using craft 4wheelrEXT or if there is another tool?
here is both cases the accurate and the none....
1- not accurate interaction created with craft 4wheelrEXT...
http://i25.tinypic.com/2806p1k.jpg
tire with black color and the obstacle is the white grid
2- accurate interaction made by hand only to make my idea clear...
http://i31.tinypic.com/j8o2ah.jpg
tire with white color for first and last position tire with gray color for movement steps and the orange grid is the obstacle
thanks.
Accurate interaction
Re: Accurate interaction
Hello Raptor and welcome to the forum. On of the features that makes Craft 4-Wheeler Extended unique from the regular Craft 4-Wheeler is the feature called "Ray Multiplier". After you're done with your animation you can increase this value for higher accuracy (but longer computational times, that's why it's good to use Resimulate) and then press Resimulate to have the animation re-created with high accuracy.raptor wrote:hi every body...
thanks.
- Attachments
- Ray Casting Parameters
- ray_cast.gif (18.05 KiB) Viewed 32682 times
is there is a help document so i can read it ?
Yep, right here: http://www.craftanimations.com/index.cf ... 515E9A19BDraptor wrote:is there is a help document so i can read it ?
You're very welcome raptor, let us know if you have any other questions.
Users browsing this forum: No registered users and 20 guests
