Crash after animation set up
cyb213
Post by cyb213 » Tue Nov 18, 2008 3:24 pm
hey ppl!
first off i'd like to say that this is a superpowerful plug-in and i m loving it!
but lets get straight to the problem:
i created some animation of 4wheeler. as long as i keep working on the scene, everything seems to be fine. then i save the file and turn off 3dsmax. the next time i try to open the same scene , max crashes... i tried to unplug all nodes before saving and saved the file. reopenning the file was unsuccessful again :(
any suggestions on what it might be?
thanx
Re: Crash after animation set up
Post by Carl Buhre » Tue Nov 18, 2008 6:54 pm
cyb213 wrote:hey ppl!
thanx
This sounds very odd Cyb213. Try (re-)installing the latest version of Craft Director Tools and see if that helps. No need to uninstall before installing, just make sure 3ds MAX isn't running when you install it.
Are you running 3ds MAX 32-bit or 64-bit? If possible, please send your scene to support@craftanimations.com and we'll take a look at it.
cyb213
Post by cyb213 » Tue Nov 18, 2008 8:26 pm
the file doesn't open neither in 32 nor in 64 bit 2008 max... :(
it says
"an error has occurred and the application will now close.
do you want to attempt to save a copy of the current scene?"
should i send this file straight to that email with no special subject in the subject line?
Post by Carl Buhre » Wed Nov 19, 2008 9:13 am
cyb213 wrote:the file doesn't open neither in 32 nor in 64 bit 2008 max... :(
it says
Yes sure, that will be ok. Unless it's too big, in that case I can set up a temporary FTP account for you.
cyb213
Post by cyb213 » Wed Nov 19, 2008 11:36 am
just sent the file to that mail.
hope to hear from you soon!
thanx for the fast response!
Post by Carl Buhre » Fri Nov 21, 2008 8:59 am
cyb213 wrote:just sent the file to that mail.
Thank you Cyb213 for sending us your scene. The bug has been fixed and is the new update is available in the latest bundle here: Craft Director Tools latest bundle
cyb213
Post by cyb213 » Wed Nov 26, 2008 7:58 am
unfortunately, installing the latest bundle didn't solve the problem with the file :(
the file doesn't open either in 64 or 32 bit max :(
any ideas?
Post by Carl Buhre » Wed Nov 26, 2008 10:08 am
cyb213 wrote:unfortunately, installing the latest bundle didn't solve the problem with the file :(
any ideas?
I’ve tried opening the scene on three 64-bit workstations, using 3ds MAX 2008 and it works on all of them.
Maybe you can try and uninstall Craft Director Tools and then install the latest version again and see if that helps. Please let me know how it turns out.
Users browsing this forum: No registered users and 156 guests
