Hi, I'm trying to rig the rear suspension but I have a problem:
The swing arm should rotate from the center of the chassis and do not know how to do it .. I have separate parts:
- Chassis
- Handlebar
- Front mudguard
- Wheels
- Swingarm (chain, etc. ..)
I need the tool "Gyro"? and if so .. how do I use?
Thank you very much!
[2 Wheeler Ext] REAR SUSPENSION SETUP
Re: [2 Wheeler Ext] REAR SUSPENSION SETUP
You can use the free Suspension tool that is included in CDS to rig the swing arm. Make the Upper part a child of the Body, the Lower a child of the WheelCenterMesh and the swing arm a child of the "spring". Make sure to initialize the suspension from the configuration before you connect something to it.
