foorever
by foorever » Tue Jan 25, 2011 1:39 am
hi,
is it possible to put the 4 wheeler extended in a crab steeting mode?
it should work like in this picture
the idea of this mode is, that the wheels run next to each other, so they don't destroy the underground that much.
when i move the back wheels to one side and then press record, the car doesn't go straight forward anymore.
cheers
foorever
by Micael Belin » Tue Jan 25, 2011 10:01 am
Hi Foorever,
Yes there seems to be a bug when the car is initializing, making it rotate when you start the recording. It only seems to be happening once on the initialization, then the car is behaving as you wish.
I recommend you simply start the recording a few frames before, drive the car to the starting point and then record it from there.
foorever
by foorever » Thu Mar 10, 2011 1:10 pm
thank you very much micael. it worked
Users browsing this forum: Majestic-12 [Bot] and 32 guests
