Why does this happen?
http://www.youtube.com/watch?v=cgkAbi3gCI8
I position the wheel scale the wheel and it resets for some reason. I tried unlinking both high and low poly mesh reseting position and scale, then relinking and it still bugs out! If i try to fix it after i recorded something the instant i move time slider it bugs. I have tried converting the controller to default, deleting all the keyframes, then fix its scale and position, convert controller back and it still bugs out after i record!
Steering wheel scale reset
Re: Steering wheel scale reset
Did you scale the wheel from start or does it just scale itself? I would suggest that you don't scale the wheel at all and just make sure its in the center of the high-poly wheel.
Sorry for late response
the scaling and default position would change after frame, i could not figure it out so i just re-skinned (rigged??) my vehicle works perfect now! I guess at some point i recorded then rescaled the steering wheel mesh bugged everything up.
If this happens again try the re-initialize button from the configure window for the 4-Wheeler Extended.notvacme wrote:Sorry for late response
