How do I get the car to follow the path plotted with the LINE?
As the video http://www.youtube.com/watch?v=VuSeLwMiFyU
how to make the car follow the line?
Re: how to make the car follow the line?
The car only follows the targetmesh (the green cross), waht you need to do is to animate the targetmesh. What we did with this particular movie was to parent the targetmesh onto a Craft DirectInputLink node (invisible in the render) and use it to animate the targetmesh.
You can also link it to a spline and animate movement as you normally do, or use Craft SplineSpeedController for advanced usage.
Yes, more how can i animate the green cross?
Witch 3d program are you using?fernandosc3d wrote:Yes, more how can i animate the green cross?
3d max 2009 64-bit
I managed to take my doubts, I was forgetting to apply the path constraint
Users browsing this forum: No registered users and 219 guests
