help C4D PROBLEM child ground / 4WheelerExt
gcpdesign
Post by gcpdesign » Sun Nov 15, 2009 9:55 pm
steps
0. create 4WheelerExt
1 . im make ground_surface (editable)
2 . make child for 4WheelerExt_01_GravityDirectionMesh
3. record
4. car fail _ bad collision (ground_surface) car twitches
(picture)
What do I do not so?
Please help
Re: help C4D PROBLEM child ground / 4WheelerExt
Post by Carl Buhre » Mon Nov 16, 2009 11:06 am
Hello gcpdesign,
I was able to re-create the error and we will have to take a look at this. A workaround you can use in the meanwhile is this:
  • * Go into the configuration window for Craft 4-Wheeler Extended
    * Edit the "Ray Multiplier" to 1 (Ray Cast Multiplier group)
    * Disable the "Use Fast Ray Cast" checkbox (Ray Cast Multiplier group)
gcpdesign
Post by gcpdesign » Mon Nov 16, 2009 2:16 pm
big thanx , only problem car body _collision bad ,droped in objects.
Post by Carl Buhre » Mon Nov 16, 2009 2:33 pm
Yeah when you're not using Fast Ray Cast, Craft 4-Wheeler Extended can only interact with 1 object.
gcpdesign
Post by gcpdesign » Mon Nov 16, 2009 3:32 pm
ok biggggyy thanks
MJones
Post by MJones » Tue Nov 17, 2009 11:59 am
This apporoach makes the simulation very very slow and impossible to actually do anything.
Any other suggestions?
By the way is there any reason why even normal simulation is very very slow in softimage xsi?
Post by Carl Buhre » Tue Nov 17, 2009 1:04 pm
MJones wrote:Hi,
Make sure Ray Multiplier is 1 and not 10, if you haven't already. If the simulation still runs slow you can try and decrease the amounts of polygons your ground has. If you don't want to edit the detail of the ground, you can create a "ghost ground" that has a few polygons that you drive on but no polygons on the sections that you won't be driving on. Don't render this "ghost ground".
ward500
Post by ward500 » Fri Nov 20, 2009 10:57 pm
I'm having a similar issue in Max 2010. Everything works fine unlinked to a ground plane. As soon as i link to any geo, even a simple plane, the car bounces backwards and floats away... spastically.
ward500
Post by ward500 » Fri Nov 20, 2009 11:10 pm
Posted too soon... found a fix in another thread.
Unchecking "Use Fast Ray Cast" seemed to fix it.
Post by Carl Buhre » Mon Nov 23, 2009 2:14 pm
ward500 wrote:Posted too soon... found a fix in another thread.
Be sure to lower Ray Multiplier to '1' instead of 10 as well, it will increase the performance.
Users browsing this forum: No registered users and 79 guests
