Single WHEEL
trimvein
Single WHEEL
Post by trimvein » Thu Jul 31, 2008 2:01 am
I want to create a single wheel and put a controller on it to control it like a car. Is this possible? Can i start with a 2-wheeler or a single wheel gear or something? I tried using the extra wheel controller and couldn't get it to work. This is like a cartoon style where a wheel is the only thing in control and it is the character itself. Hope someone can help.... thanks.
T
Re: Single WHEEL
Post by Luigi Tramontana » Thu Jul 31, 2008 6:42 pm
Hi trimvein.
If you want to use a single wheel the best choise would be to use the front wheel of the 2Wheeler Extended. Tilt the SteeringBarsMesh in a vertical position aligned with the center of the front wheel. Then you can simply hide all the other parts. Try it, for a cartoonish animation it could be perfect (:
Good luck!
Luigi TA
Users browsing this forum: No registered users and 127 guests
