I don't want to add craft director plugin to other pc. Is there anyway to export animated car only to other max scene. Right now, there is no option to bake animation in craft director.
Thank you!
How to export animated car to other max scene
Re: How to export animated car to other max scene
To make the rig not be dependent on CDS you can just unplug the model using the unplug button.
If you would like to have the keys directly on the model you can do the following:
The dummy meshes are not rendered as they are set to not be render.If you would like to have the keys directly on the model you can do the following:
- Use Position Constraint and Orientation Constraint instead of using link
- Bake the keys using Conversion Tools under Motion -> Motion Paths
- Done
Users browsing this forum: No registered users and 68 guests
