Helicopter Rig Curve control
kgr
Post by kgr » Mon Mar 21, 2022 6:54 pm
Just wanted to clarify - is there a way to control the helicopter rig with the curve?
Or it have to be resimulated every time the change is needed?
Re: Helicopter Rig Curve control
Post by Patrik Martin » Tue Mar 22, 2022 8:28 am
Unfortunately the Helicopter does not support the autonomous funcion. So making a change to the path of animation will make you need to reanimate from the point of where the change is desired.
if it's only changing some of the configuration values you are able to press Resimulate button to keep the same path. Please note that changing main physical behavior will change the path of the animation (for example rotational max velocity or response factor).
We do not have any plans at the moment to add autonomous mode to Helicopter.
Users browsing this forum: No registered users and 3 guests
