Spline Speed Controller Time Delay
srhyne
Post by srhyne » Mon Mar 01, 2021 8:12 pm
I have a scene where I want the time delay to be 1350 frames and it looks like the maximum value is 1000 frames. Is there a way to change that?
Thanks!
Re: Spline Speed Controller Time Delay
Post by Patrik Martin » Tue Mar 02, 2021 11:25 am
Thanks!
No it does not seem like something you can adjust and something we should look at fixing.
I suggest that you play with the inputs to get what you need. Basically let it stop at the intended frame then pull the timeline to the desired frame and let the carriage continue from that point using the input to force it to continue.
Users browsing this forum: No registered users and 116 guests
