i am attaching the scene with the terrain where a car drives through ramp instead of detecting it. It happens only with some mesh. Could you please let us know why some mesh works and some doesnt
Link: https://we.tl/t-wCClwLChsD
Car drives through mesh
Re: Car drives through mesh
Sometimes when there is a disconnect between objects in a mesh where the facets does not connect then the 4-wheeler can en up in these situations where it decides to continue on the same terrain.dv2000 wrote: ↑Thu Sep 26, 2019 7:02 pmHi,
To solve this the need to be united properly in to one object. The smoothest way in this situation is to use the Boolean feature.
1. Detach the ramps to new mesh
2. Select the ground
3. Go to Crate > Geometry
4. Select "Compound Objects" in the drop-down
5. Create a Boolean
6. In the Boolean parameters click on "add operands" button and select the ramps.
7. Make sure it is set to Union or Merge.
8. Make your animation
8. Done
Users browsing this forum: No registered users and 348 guests
