I use Craft Director Studio v19.1.4 in 3ds Max 2018 on Windows 10. I am having a problem with the restoring saved profile. I have created a tank rig with extra wheels. I adjusted Input Property Parameters in CrawlerExt tool. Then I created a new profile for this tank rig and saved whole rig as a template under main menu->save selected. Now, when I try to create saved rig using Main menu->Create Template->(my template), template of CrawlerExt with all extra wheels creates fine but Input Property Parameters in CrawlerExt tool have different values. I have to go to profile settings, change to another profile and then change back to my saved tank profile to restore right parameters.
Why cannot I save exact Input Property Parameters into CrawlerExt tool as a template?
Saved profile doesn't restore settings
Re: Saved profile doesn't restore settings
Hi Vipera and welcome to the forum.Vipera wrote: ↑Wed Aug 14, 2019 8:45 pmI use Craft Director Studio v19.1.4 in 3ds Max 2018 on Windows 10. I am having a problem with the restoring saved profile. I have created a tank rig with extra wheels. I adjusted Input Property Parameters in CrawlerExt tool. Then I created a new profile for this tank rig and saved whole rig as a template under main menu->save selected. Now, when I try to create saved rig using Main menu->Create Template->(my template), template of CrawlerExt with all extra wheels creates fine but Input Property Parameters in CrawlerExt tool have different values. I have to go to profile settings, change to another profile and then change back to my saved tank profile to restore right parameters.
This sounds like a bug. I will forward this info to the development team, thank you for posting.
Hi Patrick. Is there a way to get tech support ASAP?
Yes, see https://craftanimations.com/contact-us/. In general we are able to help you right away between 9am and 3pm CEST (09:00-15:00). We can also book a time outside these times if it suits you better.
Re: Saved profile doesnt restore settings
This is slightly hard for us to know. I would say that if the developer of the input device does it correct and leave the button mappings as before it should not change any behavior in CDS for you.Emilemarve wrote: ↑Sun Oct 13, 2019 1:46 pmI have flashed the new Firmware to my GF MkII MCG Pro.
Can I now load my old profile and Set it into the stick?
Is the calibration settings saved in a Profile/Config? So if I load an previous profile does it load an older calibration???
Users browsing this forum: No registered users and 202 guests
