2 steering axle
2 steering axle
how to make a two-axis steering? truck with 4 axles
Re: 2 steering axle
Use the 4-Wheeler and ExtaWheels as the steering wheels.
Place the wheels from the 4-Wheeler on the axes which move while you steer. then place the 4-Wheeler pivot pin on one of the axes which doesn't move. Then use the ExtraWheels on the axes which doesn't move. Don't forget to fixate them! (you find it in the ExtraWheel configure window)
Re: 2 steering axle
when car stoped, wheels not rotate. What to do?
Re: 2 steering axle
Make sure all tools are active while recording. Each tool has a key next to it, which indicates wether they should be recorded or not. Are any of them disabled?
Users browsing this forum: No registered users and 9 guests
