craft suspension
Re: craft suspension
Post by Patrik Martin » Wed Mar 03, 2010 9:40 am
Enigma229 wrote:Gentlemen,
Is there a quick rig setup I can use to get a better feel for suspension with a vehicle?
Well you could try to create a "Sports car with suspensions" from the "Craft Templates" creation dialog. The rigs are quite different depending on the type of model. It may help you but what I think is the best for you is to have a look at the manual for the Craft 4-Wheeler Extended and have a look at the "Suspension Rigging" section. The manual can also be found here: http://docs.craftanimations.com/?goto=t ... ended.html.
Yannick
Post by Yannick » Tue Mar 09, 2010 11:56 am
Continuing on the car leaning on one side.
It happens when I parent the ground to the GravityDirectionMesh.
This is weird because in order to get the ground to work properlly I have to parent the GravityDirectionMesh to the ground. And if I have several object for the ground, I have to combine them then parent the GravityDirectionMesh under it.
Is this a bug?
I am on Maya 2009 with Director Studio 9.4.1 (64bits).
Yannick
Users browsing this forum: No registered users and 117 guests
