hi
make first steps with craft...installed the version that shipped with max. v9.4.1 x64
work in maxdesign2011 64bit in meter/meter.
just made a 4 wheelerext., configured input running with keyboard...booster works...
when i make a spline everything works fine , exept the boosting ...it looks like it reduces the velocity of the car...
any ideas?
thanks thomes
boost problem with spline animation
Re: boost problem with spline animation
When using a spline and autonomous mode it will try to "catch" the target. The autonomous function takes down the speed if needed to be behind the target.
Its automatic process and not under any control but you should instruct accordingly.
Users browsing this forum: No registered users and 39 guests
