im new with the craft tools. ive setted up a fully working truck with a trailer. (not the template)
all works fine without ground. but i need to have a ground in and there it starts with things are going crazy.
For the truck all works fine. but the gravitynode of the trailer seems to be parented under the trailer and so of i parent or link
a ground it drives with the trailer.
is that as it should be? think not.. can someone help me?
Trailer and ground Possible?
Re: Trailer and ground Possible?
Hi Eddyvh, welcome to the forum!
May you be parenting the ground and gravitymesh the wrong way? It is true the trailer's gravitydirectionmesh is parented as a child of the trailer chassis by default. Simply re-parent the trailer's gravitydirectionmesh to the ground instead. And to clarify: It's the gravitymesh that should be a child to the ground, not the opposite way around. The 4-Wheeler works both ways, but the trailer's gravitymesh must be a child to the ground, not the parent.
Does this help?
Does this help?
yes thanks.. but if i tried that the scene was all time crashing.. now i rebuild the scene and it works.. but it is sadly very slow.
why i cant select the fast raycast for trailers also?
but very thanks for the gravity mesh solution
What system are you running? Cinema 4D?eddyvh wrote:yes thanks.. but if i tried that the scene was all time crashing.. now i rebuild the scene and it works.. but it is sadly very slow.
Users browsing this forum: No registered users and 38 guests
