Help with wheel bump
Posted: Tue Aug 02, 2011 11:48 pm
I'd welcome any help in the following matter:
A rigged truck frame and a planar ground with 3 bumps. I'd like the truck to go over the bumps to nicely see the suspension at play. Unfortunately I can't get the suspension to act realistic. The frame is bouncing together with the wheel too much. The frame needs to be more stable while only the wheel bouncing up and down. Is there any way to tweak this? Surprisingly suspension setting has no effect on this and the speed at which I drive over the bumps neither! When I look in slow motion at the recorded simulation the wheels and frame are bumping exactly the same way at quite different speeds.
I tried suspension stiffness 1000 and damping 200 and also stiffness 4000 and damping 800 and the result is identical. I also tried to change the mass multiplier but it also didn't change anything.
Here's a picture of the scene and another picture showing the rigging.
Is the rigging actually correct? In order to fit the long frame I had to scale the body quite big. Is it possible that it's influencing the result of the wheel bumps?
Also here's a video of the motion. As you can see the frame is just tilting sideways too much.
http://www.thelooopcgi.com/truck.avi
Thanks!
David
Thanks!
David
