hi,
I tried several option to make a car drift on spline speed controller tool but no luck,and I use the keyboard control it. I want to do effect as As shown in the Help Pages Skidding effect ,So can you let me know how to make a real time car drift in this plug in .Please specify. Any help would be appreciated!
Car drift effect
Re: Car drift effect
There are two ways to get the car to skid.
1.
Under the General Parameters in the configuration for 4-Wheeler Extended you find something called "Skidding Release Value (Lateral Vel Rel)". If you lower this value you will get a skidd effect. Of course you need to have a certain speed and turn angle to activate it but test your way forward with this parameter and I am sure you will find a satisfying configuration for skidding.
2.
Set up a input for skidding via the input settings. To change it's effect you are able to change the following parameters under "Input Property Parameters". Skidding Response Factor and Skidding Maximum. The first of them determains how fast the skidding is applied to the maximum value and the maximum more or less tells the car how slippery the ground is.
Hope that works for you.
1.
2.
I was testing!Thank you very much
Users browsing this forum: No registered users and 218 guests
