Multiple Ground Meshes
Posted: Thu Feb 24, 2011 6:37 pm
by patrick58d
In our scene we'd like to use multiple meshes as a ground plane without combining them into one mesh. Is their a way to accomplish this with parenting? We have tried different hierarchy combinations without any success. In this craft tutorial video this topic is briefly mentioned at around 27 seconds and the possibility of parenting is mentioned. http://www.youtube.com/user/craftanimat ... cHtpSIvJC8
We are running craft version 10.1.4x64 in Max 2011. Thanks in advance!
Re: Multiple Ground Meshes
Posted: Fri Feb 25, 2011 12:16 pm
Parent/Linke the ground meshes to the GravityDirectionMesh. This only works for the 4-Wheeler Extended.
Posted: Fri Feb 25, 2011 11:29 pm
by patrick58d
Hi Patrik,
Thank you for your reply. This is exactly what I have done. I've parented (linked in the case of MAX) the GravityDirectionMesh to the multiple ground meshes with no success.
Posted: Mon Feb 28, 2011 10:07 am
patrick58d wrote:Hi Patrik,
Try the other way around. The meshes to the GravityDirectionMesh.
Posted: Thu Mar 10, 2011 8:16 pm
by patrick58d
Hi Patrik,
Thank you for your reply. I have tried ever possible parenting combination, and none seem to work including parenting the ground meshes to the GravityDirectionMesh.
Posted: Fri Mar 11, 2011 8:31 am
Strange... are you able to place a link to the scene so that I can have a look at it? Remove the things that are sensitive if you like. Also it's good if you tell me which version and program that you are using.
