Slow-Motion not working
Posted: Fri Nov 26, 2010 5:23 pm
by juang3d
Slow-motion is not working in the latest update of the plugin for 3ds max, the slow-motion multiplier don't change from 0 even when you press 1 or 2 or the spinners, it stays at 0, is there any solution?
Cheers.
Re: Slow-Motion not working
Posted: Sun Nov 28, 2010 11:53 pm
by juang3d
Hey! Hi!
No answer at all? there is no one with this problem?
Cheers.
Posted: Fri Dec 03, 2010 1:47 pm
by Micael Belin
Hi Juang, sorry i haven't replied earlier.
It appears to be a glitch in the slow-motion factor spinner, it only updates once you leave focus from it. As a workaround you can set the slow-motion factor, then click somewhere else to leave focus, and the slow-motion should update accordingly.
I have registered this issue as a ticket to fix.
