Is there a way to show the acceleration Rate?
Posted: Fri Aug 13, 2010 1:14 am
by ddustin
Is there a way to display what the rate of acceleration of a Craft 4WXT object is?
Many times we are given certain acceleration rates by our clients and it would be handy to have a feature like that (assuming it does not exist currently).
Thanks,
David
Re: Is there a way to show the acceleration Rate?
Posted: Fri Aug 13, 2010 9:45 am
by Micael Belin
There is no direct way of telling the acceleration rate of the 4-Wheeler when driving, at least there is no support for it within the module itself.
Of course, you can do this rather simple in scripts, basically reading the acceleration by reading the position change from the last two keyed positions and current position.
Posted: Fri Aug 13, 2010 2:32 pm
by ddustin
Simple for you Micael
What would be involved with writing a script that would use something like 2 dummies, one stationary the other attached to an object, then print the value in the max script listener (I could take it from there)?
Thanks for your help.
David
Posted: Fri Aug 13, 2010 2:57 pm
by Micael Belin
Honestly, i have no idea how max script works
I merely use the C++ API for our interaction. If you would like i can help you develop a simple tool, but i would have to charge you for it... Give me a formal request on
support@craftanimations.com if this would be of interest. Otherwise i bet there are a lot of tutorials available for max scripts, maybe even finished solutions? I'm sorry i can't help you with any references though.
Posted: Fri Aug 13, 2010 3:57 pm
by ddustin
Micael,
Would the application run inside Director Studio or would it be free standing?
Thanks for the feedback,
David
Posted: Mon Sep 13, 2010 2:11 pm
by Micael Belin
It can be either or. The benefit of running within Craft Director Studio is that it will automatically be available on all our supported platforms and host programs. However a standalone solution would be able to be more integrated within the target host application. It's pretty much up to how you want it.
