4 wheels problem Cinema 4D
Posted: Fri Nov 13, 2009 2:06 pm
by freak78
Hello Craft Team,
I have Cinema 4D and 4Wheeler Free. The Wheels go to the half in the Ground ? The Problem is the Scaletool from Cinema 4D.
Scaled in the "Koordinate" on right Side is this ok ! Scaled with the Scaletool is the Problem avaiable.
Please Help.
Re: 4 wheels problem Cinema 4D
Posted: Fri Nov 13, 2009 2:14 pm
GravityDirectionMesh needs to be a child of your ground object and the ground object must be Editable (Hotkey: C).
Posted: Fri Nov 13, 2009 3:33 pm
by freak78
Carl Buhre wrote:GravityDirectionMesh needs to be a child of your ground object and the ground object must be Editable (Hotkey: C).
The Problem is the Scaletool from Cinema 4D. When i Scale the CraftCar-Mesh with the Scaletool go the wheels to half in the Ground (GravityDirectionMesh->ConvertetGround).
When i Scale per Hand in the right Side under the Objektlist-->Koordinate is no Problem.
Posted: Fri Nov 13, 2009 3:42 pm
You have to use the Object Tool when you scale, otherwise you're just scaling the dummy mesh data, not the transform. See the attached picture to this post.
Posted: Fri Nov 13, 2009 3:56 pm
by freak78
Thanks !
This is it !!!
Posted: Sun Nov 15, 2009 5:21 pm
by gcpdesign
Similar problem
All is made by rules, but the car fails in the ground. Why?
Posted: Mon Nov 16, 2009 3:29 pm
gcpdesign wrote:Similar problem
http://forum.craftanimations.com/viewto ... ?f=2&t=626
