Car race scenario
Posted: Thu Dec 11, 2008 9:50 pm
by Robertxyz
Is there a way to set up two vehicles "racing" each other down a highway scenario?!? I only have the 4 Wheel Ext plugin.
Thanks!
Re: Car race scenario
Posted: Fri Dec 12, 2008 2:24 am
by ddustin
Robert,
Couln't you set up 2 cars and have them both controlled seperate input devices?
Then you could race each other and record it.
David
Posted: Fri Dec 12, 2008 2:31 am
by Robertxyz
So you mean, use TWO controllers (gamepads).. and have another person drive the second car?!? I'll clone the car and try it!
Posted: Fri Dec 12, 2008 2:39 am
by Robertxyz
Hey David, that works! But Im gonna look for a more "controlled" way to run them on a highway...that way as I film then one speeds up over the other and vice versa as they take turns etc.
But what you suggested is a good starting point.
Thanks!
Robert
Posted: Fri Dec 12, 2008 3:25 am
by ddustin
Robert,
Glad it worked for you.
Make sure to show us something after you get it working.
David
Posted: Fri Dec 12, 2008 11:29 am
by Luigi Tramontana
interesting (:
If you use a SSC with autonomous mode, and attach a DIL (direct input link) to the carriage/dolly you will be able to control the cars quite rigorously.
Posted: Fri Dec 12, 2008 12:45 pm
by ddustin
Luigi,
He doesn't have the SSC, just the 4wext.
David
Posted: Fri Dec 12, 2008 1:12 pm
by Luigi Tramontana
hmm, right. Well in that case one could of course use (the more cumbersome) motion path keyframing on a DIL cage and then attach the target to the actuator. Acutally, not a DIL if it's lacking, but rather two 1D-translators (with the top one's cage parented to the bottom one's actuator).
