Weird missile guidance behavior
I am trying to use Missile operator to simulate missile launch from ground launcher. I am having a problem with missile orientation during initial missile flight path. The problem is that even missile moves up the missile orientation is with nose down. I tried to tweak various parameters but I cannot eliminate such behavior. What do I have to change to fix it if this is really possible?
Re: Weird missile guidance behavior
Yes, that looks a bit odd. The target where is it? on the ground?
The target is behind the image frame at left top corner, about few hundred meters away.
Here is .max file with CA missile animation where I have problem with missile orientation during flight.
https://www.dropbox.com/scl/fi/8yhru70c ... 3e6oa&dl=0
Users browsing this forum: No registered users and 124 guests
