Tiny stutter/jerkiness
dv2000
Post by dv2000 » Fri Jul 28, 2023 10:56 pm
If i simulate a car driving then go to the middle of that simulation, for example, and start simulating again from the middle the simulations 1 and 2 will have a very suddle stutter. It is barely noticeable but still noticeable when simulations 1 and 2 meet.
Vipera
Re: Tiny stutter/jerkiness
Post by Vipera » Fri Aug 11, 2023 12:56 am
When you make your simulations make sure simulated object is not far way from origin of coordinates 0,0,0. Otherwise you will have some jerkiness in animations.
Post by Patrik Martin » Fri Aug 11, 2023 11:33 pm
Ok thank you for letting us know. We will test it out.
dv2000
Post by dv2000 » Thu Sep 07, 2023 5:52 pm
Maybe 3ds max precision values get worse farther away you go from 0,0,0. Unfortunately we have a terrain 5 miles and we have to use system units in inches since most models sold are in inches
Vipera
Post by Vipera » Mon Sep 11, 2023 9:50 pm
I have similar problems. What I do, I link terrain and all objects in the scene to master Point helper or Dummy. And for each scene I move this master point object such way that my scene on terrain was about origin of coordinates 0,0,0. Then I animate CA vehicles on terrain. CA vehicles are not linked to master point object. If I have a few scenes in different locations on terrain, I also have few point helpers for each scene which are markers where I need to move my master Pont helper to keep each scene around 0,0,0. And I just hide/unhide layers with CA vehicles for each scene. I hope my description is clear.
Users browsing this forum: No registered users and 279 guests
