I have a scene where I want the time delay to be 1350 frames and it looks like the maximum value is 1000 frames. Is there a way to change that?
Thanks!
Spline Speed Controller Time Delay
Re: Spline Speed Controller Time Delay
No it does not seem like something you can adjust and something we should look at fixing.
I suggest that you play with the inputs to get what you need. Basically let it stop at the intended frame then pull the timeline to the desired frame and let the carriage continue from that point using the input to force it to continue.
Users browsing this forum: No registered users and 41 guests
