Problems with moving platforms
Hi, I know you told us that platform can go up and down but not move forward and backwards with a vehicle on top. Also even massfx and Bullet simulator have problems with moving platforms side to side. is there a reason why it is so hard to do.
We have to animate a car that drives up on top of a moving train wagon and they starts driving from wagon to wagon. I wonder why is it difficult for any software to have two separate movements - movement of a train and separate movement of a car. Are there any tricks?
Re: Problems with moving platforms
I will ping one of our developers to have a stab at this question
I think we found the solution
here is the scene link https://we.tl/t-sepMwRYfVk
What we did is animated our car on stationary wagons. Then converted car body to PBR. Then we linked animated car body to the train wagons. And only then we used path constraint for train wagons to move
This works when train is moving in one line so multiple wagons can be one mesh for our car to jump from one wagon onto another.
But when train is following a curved path wagons rotate and now we cannot have one single mesh. Not sure if there is a way to have multiple meshes as a terrain
But we still dont know how to make a car drive up on a to a moving platform .Not only we cannot link it because the car will be on the ground first. Also we have to have two terrains the ground and a train wagon.
The reason why we are having problems with moving grounds is that the tools expect them not to move. Calculating full physics is very hard, and if you have to take in consideration of external forces it gets even harder. In order for our tools to run and simulate in realtime, we take shortcuts.
My suggestion is that you try not to make the sequence as a whole, but rather record each movement individually and then stitch them together manually.
Thank you!
I know it is off topic but Cinema 4d Drive plugin 2.0 offers car collisions with objects and each other . https://c4dplugin.com/product-drMicael Belin wrote: ↑Thu Sep 12, 2019 9:23 pmHi,
Would be nice to have it too
This can be made with physics engines but it would of course be simpler if it is integrated to function in the tool.dv2000 wrote: ↑Thu Sep 12, 2019 9:52 pmI know it is off topic but Cinema 4d Drive plugin 2.0 offers car collisions with objects and each other . https://c4dplugin.com/product-dr
Need to make a tutorial on this using a physics engine.
Thanks. Could you guys look into TYFlow. I think it can help
tyflow https://www.instagram.com/_tyflow_/?hl=en
Hi,Patrik Martin wrote: ↑Thu Sep 12, 2019 4:28 pmI will ping one of our developers to have a stab at this question![]()
We animated a moving car on the stationary platform. Linked the platform to a moving dummy. But when we linked craft car to the platform car start flying to the side instead of driving on top of a moving platform. Any solutions?
ok it looks like we fixed it. The train terrain mesh was created on an angle because the train is moving downhills. So we had to create a cube alighted to the origin and then attached terrain mesh to the cube in edit poly. I guess craft needs terrain mesh to be perfectly aligned with world space
Nice workaround dv2000! Thanks for letting us know.dv2000 wrote: ↑Wed Jan 29, 2020 5:41 pmok it looks like we fixed it. The train terrain mesh was created on an angle because the train is moving downhills. So we had to create a cube alighted to the origin and then attached terrain mesh to the cube in edit poly. I guess craft needs terrain mesh to be perfectly aligned with world space
Glad you found a solution.dv2000 wrote: ↑Wed Jan 29, 2020 5:41 pmok it looks like we fixed it. The train terrain mesh was created on an angle because the train is moving downhills. So we had to create a cube alighted to the origin and then attached terrain mesh to the cube in edit poly. I guess craft needs terrain mesh to be perfectly aligned with world space
We should maybe find a way to better handle the terrain animations so that the translation of the object the 4-Wheeler Extended Gravity Direction mesh is connected to is added as an offset to the animation of the 4-Wheeler.
Users browsing this forum: No registered users and 342 guests
