is there any way to drive a car fast on a curvy road around 200 miles an hour.
We tried all parameters and car just becomes unstable after 150 (current velocity value)
We tried steering wheel response factor It is either not enough or too much (also car shake left and right a lot). We use Logitech steering wheel. Once car is moving fast it's impossible to steer well.
I attached the max file with the road and a video. Can you drive on it fast?
Link https://we.tl/t-edL3IiOHtV
Thank you
stable car on curvy road
Re: stable car on curvy road
We will look further in to this issue but do you experience the same issue if you use slow motion factor to slow down the recording?
Hi, I never used this option. Could you tell me where can I find it. THanksPatrik Martin wrote: ↑Wed May 22, 2019 8:37 amWe will look further in to this issue but do you experience the same issue if you use slow motion factor to slow down the recording?
It is just above the "Record" button in the main window of Craft Director Studio.
Users browsing this forum: No registered users and 57 guests
