2 steering axle
SHIBLEV
2 steering axle
Post by SHIBLEV » Mon Nov 05, 2012 8:48 pm
how to make a two-axis steering? truck with 4 axles
Re: 2 steering axle
Post by Micael Belin » Fri Nov 09, 2012 7:36 am
Use the 4-Wheeler and ExtaWheels as the steering wheels.
Place the wheels from the 4-Wheeler on the axes which move while you steer. then place the 4-Wheeler pivot pin on one of the axes which doesn't move. Then use the ExtraWheels on the axes which doesn't move. Don't forget to fixate them! (you find it in the ExtraWheel configure window)
SHIBLEV
Re: 2 steering axle
Post by SHIBLEV » Fri Nov 09, 2012 11:44 pm
when car stoped, wheels not rotate. What to do?
Re: 2 steering axle
Post by Micael Belin » Tue Nov 13, 2012 9:03 am
Make sure all tools are active while recording. Each tool has a key next to it, which indicates wether they should be recorded or not. Are any of them disabled?
harrybro
Re: 2 steering axle
Post by harrybro » Mon Nov 19, 2012 7:11 am
Thank you very much for reply...
harrybro
Users browsing this forum: No registered users and 118 guests
