With 3ds max 11 because you can not change World Space Maximum Velocity Gauge?
Please enter a value (example 220), press record, but the value is 49.4489
What should I do?
Re: World Space Maximum Velocity Gauge
I am having a similar problem. No matter what I enter, it snaps back to a previous value. I have tried saving my profile, reinitializing my vehicle, etc, but it always snaps back to the setting I don't want.
The reason for this is that it's not made to be changed, it's just a gauge to show the actual seed, i'm sorry for the misunderstanding text field. To change the top speed and acceleration you change the fields Gas Pedal (Forw/Backw) Maximum and Gas Pedal (Forw/Backw) Response Factor. You find these in the bottom of the configuration for the 4-Wheeler Extended.
Awesome. Thanks!Patrik Martin wrote:The reason for this is that it's not made to be changed, it's just a gauge to show the actual seed, i'm sorry for the misunderstanding text field. To change the top speed and acceleration you change the fields Gas Pedal (Forw/Backw) Maximum and Gas Pedal (Forw/Backw) Response Factor. You find these in the bottom of the configuration for the 4-Wheeler Extended.
Users browsing this forum: No registered users and 69 guests
