I set up a trailer following a 4WE. The trailer also includes 2 ExtraWheels. The 4WE and the ExtraWheels all behave more or less as expected, but the wheels on the trailer itself are not spinning. The suspension seems to be working, but the wheels simply don't spin.
Another question I actually had was, there is a wheel center mesh for the trailer and the 4WE, but there isn't such a thing for the ExtraWheel. Scripting isn't my strong suit, though I have some experience. Are there any suggestions for helping to create a wheelCenterMesh for my extra wheels?
Trailer wheels not spinning
Re: Trailer wheels not spinning
Okay, I just wound up creating some extra wheels and using those in place of the trailers wheels. They are bound to the trailer's mesh, though, so they behave fairly close to as expected.
I also solved my centermesh issue with some creative constraints.
Which system, 3d program and versions are you using? We have never heard of the wheels not turning.
You can create your own WheelCenterMesh by using the tool Gyro. Place it in the center of the wheel and make the "Box" a child of the wheel. Connect the part you like to use on the center to the "Arrrow".
I'm using 3ds Max 2011, Win7 64bit, CDT: 10.1.4.Patrik Martin wrote:Which system, 3d program and versions are you using? We have never heard of the wheels not turning.
I have done test with the same system setup and the trailers wheels are turning as they should. What type of surface are you running on? Just an ordinary mesh/poly?
Users browsing this forum: No registered users and 272 guests
