Steering wheel scale reset
notvacme
Post by notvacme » Wed Jan 19, 2011 9:15 am
Why does this happen?
http://www.youtube.com/watch?v=cgkAbi3gCI8
I position the wheel scale the wheel and it resets for some reason. I tried unlinking both high and low poly mesh reseting position and scale, then relinking and it still bugs out! If i try to fix it after i recorded something the instant i move time slider it bugs. I have tried converting the controller to default, deleting all the keyframes, then fix its scale and position, convert controller back and it still bugs out after i record!
Re: Steering wheel scale reset
Post by Patrik Martin » Wed Jan 19, 2011 9:57 am
Did you scale the wheel from start or does it just scale itself? I would suggest that you don't scale the wheel at all and just make sure its in the center of the high-poly wheel.
notvacme
Post by notvacme » Mon Jan 24, 2011 5:12 pm
Sorry for late response
the scaling and default position would change after frame, i could not figure it out so i just re-skinned (rigged??) my vehicle works perfect now! I guess at some point i recorded then rescaled the steering wheel mesh bugged everything up.
Post by Patrik Martin » Tue Jan 25, 2011 9:02 am
notvacme wrote:Sorry for late response
If this happens again try the re-initialize button from the configure window for the 4-Wheeler Extended.
Users browsing this forum: No registered users and 258 guests
