Slow-Motion not working
juang3d
Post by juang3d » Fri Nov 26, 2010 5:23 pm
Slow-motion is not working in the latest update of the plugin for 3ds max, the slow-motion multiplier don't change from 0 even when you press 1 or 2 or the spinners, it stays at 0, is there any solution?
Cheers.
juang3d
Re: Slow-Motion not working
Post by juang3d » Sun Nov 28, 2010 11:53 pm
Hey! Hi!
No answer at all? there is no one with this problem?
Cheers.
Post by Micael Belin » Fri Dec 03, 2010 1:47 pm
Hi Juang, sorry i haven't replied earlier.
It appears to be a glitch in the slow-motion factor spinner, it only updates once you leave focus from it. As a workaround you can set the slow-motion factor, then click somewhere else to leave focus, and the slow-motion should update accordingly.
I have registered this issue as a ticket to fix.
Users browsing this forum: Majestic-12 [Bot] and 302 guests
