1- Is it possible to change the time when a simulation happens? (without unpluggin)
May be deleting all the keyframes and starting over in another frame.
thanks
move simulation (frames)?
Re: move simulation (frames)?
Unfortunately, you cannot move the simulation time. Either finish the recording, unplug and then move the keys. Otherwise i would simply recommend you to make the recording again, this time on the correct timeframe. Unless you have a very complicated recording, it usually doesn't take too much time to re-record the event.
Users browsing this forum: No registered users and 19 guests
