mesh wheel /surface probleme
corabica007
Post by corabica007 » Sat Apr 17, 2010 6:02 pm
hi
i have a probleme with car wheel mesh (it's illustrated in the image)
so what parameter i can adjust so the car wheel mesh interact with surface without penatrating in it?
thanks!
Re: mesh wheel /surface probleme
Post by Patrik Martin » Thu Apr 22, 2010 2:02 pm
corabica007 wrote:hi
...image...
thanks!
Under the Ray Cast Parameters in the configuration for the Craft 4-Wheeler Extended you are able to find the parameters you need to change in order to be able to have a more detailed ground detection. Raise the "Ray Multiplier" and change the "Degrees Per Ray" to fit your needs of detection. Notice that this will need more computer power to calculate. Good to do is to first have this set to low, animate the path, then change the parameters and click on Resimulate.
Good luck
Users browsing this forum: No registered users and 37 guests
