sphereCam vibrates like hell (c4d)
Postby wombat on Mon Mar 15, 2010 6:16 pm
I have problems using the SphereCam (maybe same with other cams but this one is the first I have used so far). I'm using Cinema 4d 11.5
First I did a short test drive using the 4Wheeler Ext and parented the SphereCam to it - so far no problems. After a while I was pleased with the car animation, so I switched off the 4Wheeler's key symbol in the craft director studio window. Now I want to re-record the simulation - this time with a prekeyed car and a SphereCam that still can be driven by keyboard. Unfortunately now the "SphereCam_01_SphereCam" is stuttering like hell. "SphereCam_01_TargetMesh" isn't shaking and also the car animation seems to be ok but "SphereCam_01_SphereCam" is vibrating and stuttering as soon as "SphereCam_01_TargetMesh" is parented to a fixed keyed object :-(
Clicking the "resimulate" button doesen't change anything.
I have also tried to do a simple setup with a cube that is animated in a linear way. Then I generated a new SphereCam and parented "SphereCam_01_TargetMesh" to the animated cube: same result - "SphereCam_01_SphereCam" is stuttering :-(
Can anyone help me ?
wombat
Re: sphereCam vibrates like hell (c4d)
Postby Micael Belin on Wed Mar 17, 2010 3:00 pm
Which version of CDS are you using? I recognize your problem, especially within the CINEMA 4D environment, but the issue was resolved with 9.4.1 i think. Make sure you have the latest version of CDS (download it from out homepage, http://www.craftanimations.com) and let us know if your issue is still there then.
Development Manager
Postby wombat on Thu Mar 18, 2010 4:36 pm
Thanks - after upgrading to the newest version the problem is gone.
Cheers
wombat
Return to Support
Users browsing this forum: No registered users and 1 guest
cron
