When burning out, wheels turn backwards
ward500
Post by ward500 » Fri Dec 11, 2009 8:31 pm
Didn't notice this until i changed frame rate to 240 from 24 so that i could cut to a slo-mo burnout shot. The wheels very clearly are spinning in reverse. It does this both from a stand-still, and also when using the burnout while driving to do a doughnut.
Anyone else run into this? I'll manually reverse the rotation for now.
Re: When burning out, wheels turn backwards
Post by Carl Buhre » Mon Dec 14, 2009 1:12 pm
ward500 wrote:Didn't notice this until i changed frame rate to 240 from 24 so that i could cut to a slo-mo burnout shot. The wheels very clearly are spinning in reverse. It does this both from a stand-still, and also when using the burnout while driving to do a doughnut.
Ward,
What host application are you using? 3ds Max, CINEMA4D etc? I did a test in Craft Director Studio v9.3.1 using 3ds Max 2010 Design (32-bit) and it's rotating normally for me.
Post by Carl Buhre » Mon Dec 14, 2009 1:38 pm
I tried the Burnout in CINEMA 4D and I'm getting some strange rotation so that's probably what you were talking about. We'll look into it and hopefully we can have it sort for the next release (early 2010).
ward500
Post by ward500 » Tue Dec 15, 2009 12:41 am
Max 2010
4wheeler ext 9.2.1
I animated everything at 24 fps and it rendered visually fine. Then changed frame rate to 240 for a small segment, which will change the timeline accordingly, I just playback at 24fps for 10x slo-mo effect. When rendered, they definately go backwards. Not just the classic shutter effect of wheels turning backwards. Valve stem goes bckward too.
Thanks for looking into this. I can't verify in 9.3.1 yet as we're having farm issues with it.
Post by Carl Buhre » Wed Dec 16, 2009 9:36 am
ward500 wrote:Max 2010
4wheeler ext 9.2.1
What kind of issues are you having with 9.3.1?
ward500
Post by ward500 » Mon Jan 11, 2010 9:56 pm
Sorry, was out of the office for a few weeks there.
9.3.1 issues are just licensing things with our setup. IT guys have been working with you on that one. Took a screen grab of the curve which definately shows reverse rotation happening. Starts spinning the correct direction, then for some reason goes backwards, then towards the end, goes back to normal.
I'm scaling and moving keys to fix for the time being, but would be a nice one to get fixed.
ThanksImage
Post by Carl Buhre » Tue Jan 12, 2010 10:56 am
Hmm, you're right. I can confirm this in 9.3.1. Unfortunately we're just putting the final touches on 9.4.1 so we will not be able to get a fix for this in time for its release. We'll included it in the next release though. Thank you for reporting this!
Users browsing this forum: No registered users and 101 guests
